Which dizzy for my TPI swap?
Old May 29, 2006 | 08:54 PM
LCOwner's Avatar
I have 2 small cap HEI distributors (1103749 & 1103880) I was planning on using with my TPI swap. The block is an old 4 bolt 350 with a flat tappet cam. Can I use either of these be used safely without damaging the gears and waisting the engine? Thanks.
Old May 29, 2006 | 11:48 PM
robert1's Avatar
Yeah, either one will work fine. I think the problems come in when people use a stock distributor with an aftermarket roller cam.
Old May 30, 2006 | 02:16 AM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
I originally though that there was a difference between the newer and older distributers as well, but that isn't the case.
I do believe the difference is between roller and non-roller cammed engines. I've ran a 89 small cap HEI on a 73 block & cam for a while with no concerns
Old May 31, 2006 | 10:15 AM
LCOwner's Avatar
Thanks for the input!
junkcltr
Aug 2, 2019 11:12 PM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
92projectcamaro
Aug 6, 2015 01:20 PM
