CAT REMOVED/ HISSING SOUND AT IDLE
Old May 30, 2006 | 10:59 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Hey Guys, Im back in business as of today cuz I just bought an 89 Formula 350. The car is all stock except for a Flowmaster catback, a custom Y Pipe, and the Cat was removed. The car runs o.k. but seems just a lil sluggish off the line. It's also throwin a check engine light(which I will get scanned soon) but what I was wondering about was the loud hissing noise at idle. Its seems to be coming from under the car and it goes away while on the gas. Could this be something with the air injection system? Cuz from what I remember it should plug somewhere into the cat.(which has been removed)
Old May 30, 2006 | 11:13 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Could very well be the AIR system. Is the rest of it hooked up? The AIR feeds exhaust from your headers down to your cat, and if that cat is gone and the AIR is still there, then all that air is just getting let out of the pipe that was hooked up to the cat.
Old May 30, 2006 | 11:32 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
thats what i was thinking. im gonna check it out tomorrow and see if the air pump is even still on the belt drive.
Old May 31, 2006 | 07:36 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
might explain that code too,
Old May 31, 2006 | 07:57 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
from what i understand the smog is not controlled by the computer. i have removed my smog pump and left the end connectors unplugged and it hasnt thrown a code.
Old May 31, 2006 | 09:56 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
yes same with me. I did my 87 and my friends 89 trans am. No smog pump, no code. My 1st bet on the code is the O2.
db057
Sep 4, 2015 07:57 AM
Out-Cast
Aug 22, 2015 07:49 PM
chazman
Aug 22, 2015 02:01 PM
BurlyChev
Aug 16, 2015 09:08 PM
gta power
Aug 13, 2015 06:15 AM
