305/350 computer the same for TPI?
Old Jun 4, 2006 | 03:14 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
I have a donor 305 TPI w/ computer/wiring etc. I'd like to know if it can be used on a 350 if I do some PROM work on the chip. I understand that the manifold/runners/plenum were the same on both engines. Will I need a new computer to make it work? I tried a search, but it didn't work. Anyone else try this before? If it works as easy as I'm told (plug and play) I might use the TPI on all my future projects. I'm gonna have to learn more about PROM though! Thanks for any help.... Daniel U
Old Jun 4, 2006 | 06:09 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
yes the ECM is the same for both engines, BUT the memcal/prom chip is different. Several other things will have to be changed also. Knock sensor for one. If the car is a Mass Air Flow setup you will propably have to change the Electronic spark Control module on the firewall.
I'm in the process of swapping my 305 TBI for a 350 TPI. I wish I had a donor car.
Old Jun 4, 2006 | 03:48 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
I neglected to mention this 350 is going into a smog exempt 1954 Chevy pick up. Does this help me any?
Old Jun 5, 2006 | 05:09 AM
techno101's Avatar
Car: 1989 Camaro RS
it should help a lot actually. You probably won't use some of the connectors on the harness. Depends on if you're using a mechanical fan or electric. Also our cars use HEI distributors, not sure what your going with on your engine. There are a few other things but its early wher I'm at and I can't think right now.
Old Jun 5, 2006 | 09:45 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Any help is useful. I've never done this before. I will be using the HEI style on my truck as well as an electric fan.
Old Jun 6, 2006 | 04:50 AM
techno101's Avatar
Car: 1989 Camaro RS
there is a book called TPI swappers guide. Pick it up, it'll help,
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
