Filter or no filter at the strip?
Old Jun 4, 2006 | 12:41 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
If i take out the k&n's in my filter tray just for some strip action, will i see a difference. I tried a search, but i remember someone posting that the ridges on the filters smooth the incoming air... I have a ram-air set up thru the foglights, but it gets really restrictive over the radiator (stock airlid is thin). I was also considering taking off the airlid and adjusting my hood pins so the hood is slightly gapped and air gets a straight shot into the TB... Has anybody tried this? Im only going to do this at the track remember.
Old Jun 4, 2006 | 01:48 PM
MdFormula350's Avatar
I think I tried it when i was stock and had my 88 formula 350, I dont think it did anything at all, plus running without a filter didnt even seem like a good idea but i wanted to try it anything.
Old Jun 6, 2006 | 10:28 PM
SGT.ROCK's Avatar
Car: 1989 Trans Am
Transmission: 700R
Axle/Gears: 9 bolt 2.77
I have a Ram Air hood and air box an my car and I also wondered about that.But when I recharge my filter I do notice some big'ol bugs stuck in there so if I try it it will be at the track or for a spin down the road and back.
Old Jun 7, 2006 | 12:30 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I have a ram air setup thru the foglite area (lites are removed) and when I pull my K&N filters out my car gains another 1.5 MPH in the 1/4 mile.
Old Jun 7, 2006 | 12:47 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
Old Jun 8, 2006 | 08:08 AM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
I've seen cars back fire out the intake for not having the air filter on, it even happened on my 82 camaro after rebuild. On a 86-89 car it may cost you your MAF.
Old Jun 8, 2006 | 11:35 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
When I was running high 13's at 100 mph, I would gain 1 mph and .1 second by adding my ram air ducts that pull air from the foglight area. I haven't re-tested since I got down to the mid-12's at 110 mph, but probably will this summer or fall. As far as running without an air filter, I wouldn't want to risk having the engine suck something in and ruining a good day at the track.
skinny z
Carburetors
Sep 29, 2015 11:25 PM
R13_Braz
Sep 18, 2015 05:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Amillionoh7
Sep 5, 2015 11:44 PM
