what would it take...
Old Jun 5, 2006 | 01:15 PM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Transmission: Swapped in T5
to put a 305 tpi 5 speed tranny on a 350 tpi?
Old Jun 5, 2006 | 05:42 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
A 350 5 speed flywheel, thats it unless the car is set up for auto.
Old Jun 5, 2006 | 07:37 PM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
yes the car is originally 700r4. so ima need alot more than just the flywheel.
Old Jun 5, 2006 | 09:30 PM
TheKeeling's Avatar
Car: 1985 Z28
Engine: 5.7 TPI Crate Motor with Vette PROM
Axle/Gears: Richmond 3.42
You'll need to drill holes in the firewall for the clutch master cylinder, on mine, I used a piece of paper to trace the basic location of the holes on my donor car, then used a hole saw, and some drills for the other. You'll also have to cut a hole in the floor for the shifter too. (make sure the shifter hole is big enough, I made mine too close to the trans, so it makes a banging noise when I abuse my T-5.
Old Jun 6, 2006 | 01:07 PM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
haha new idea. my 350tpi is going in the back of my 86 fiero gt.
Old Jun 6, 2006 | 04:51 PM
TheKeeling's Avatar
Car: 1985 Z28
sweeeet!
loomdog32
Nov 24, 2012 09:17 PM
MyLT1hasaCamaro
Oct 6, 2012 12:42 AM
superbird91
Sep 11, 2012 05:28 PM
88fastgta
Sep 6, 2011 08:32 AM
