TPI manifold base
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
TPI manifold base
does any one know if there is a difference between the 1986 and 1987 TPI manifold base?Is there a difference in the bolt pattern or the bolt angle or is there any at all?Thanks in advance
Cant really speak for the F-body bases but I kow that the 85-early 86 corvette base that went with cast heads was the same for both years. As soon as they went to aluminum heads the center bolt angles changed when bolting up the heads.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, the 86 intake has the older style intake bolt pattern, while the 87+ has the four middle holes at a different angle.
Car: 87 IROC Z
Engine: 5.7 L98 TPI
I have the alluminum corvette L-98 heads,also used on the zz-4 engine.When i bought them i had to by a 1986 base,but id like to port my 1987 base and put it back on.Im also looking for an aftermarket base,whatever is cheapest
I have those heads too. Definitely go with the aftermarket base. You can only port the stock base so far, and the aftermarket base is still bigger.
Car: 87 IROC Z
Engine: 5.7 L98 TPI
I would love to get an aftermarket base but at the time they are too expensive
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
My 350 engine has a differnet angle holes because I had to modify the stock intake holes to a steeper angle. It was really easy with a dremel tool too. The stock intake I have has holes that were more straight down before the modfication. I ported it and polished the crap out of it inside. I noticed a better throttle response and I'd say gained a few upper rpm's too. (Along with porting and polishing the plenum, and polishing the throttle body.)
1992rs/ss
Jan 31, 2025 05:10 PM
Sanjay
Aug 12, 2015 03:41 PM
