Custom Intake Over Stock Fork Intake
Old Jun 6, 2006 | 12:15 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I started looking into fabbing up a CAI for my camaro with the forked type intake. I have the fog lights removed and ducting running up to the filters. I don't like how thin the airbox is though, looks extremely restrictive.
Would it be worth it to get rid of my "ram air" intake system with restrictive airbox over a freer flowing CAI without a "ram effect"?
Old Jun 6, 2006 | 12:17 AM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
the only way to see if it is really worth it is to take it to the trak and see how the car reacts to it
later
and
GB
rk
Old Jun 6, 2006 | 12:26 AM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
I don't think you'll see much(at all) of a gain. Camaro Intakes are pretty good, and your's is setup even better.
But if you want to, go ahead, like you said, if think that the intake is restrictive and it will give you peace of mind to do something about it---do it.
Old Jun 6, 2006 | 12:57 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i think mine is restrictive, i read somewhere on here someone used the stock tpi air cleaner assembly on an stock ls1 swap and he dynoed it, then when he removed the tpi air cleaner, and dynod again, 17hp was gained.
Old Jun 6, 2006 | 01:44 PM
Yeah, I think that it could be a serious bottle neck because the cleaner box is about 3/4" tall, which is pretty thin imo. I just wish there was a way to make the box taller without the hood hitting it.
Old Jun 6, 2006 | 02:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
im actually looking into fabbing the lt1 cold air to work on my car here shortly... next month or so.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
