What is this sensor on the passenger cylinder head?
Old Jun 8, 2006 | 11:45 PM
bneuberthz's Avatar
Car: 87 Iroc Z
Engine: l98
Transmission: th 350
Hi everyone,
On the passenger side cylinder head on a 350 top there is a sensor between the numbers 6 and 8 spark plugs. I need to know what it is. There was an oil leak in my car and the number 8 wire and the block below it have oil on them. The sensor right there is broken and it appears this is where the oil is leaking. I need to know what this sensor is so I can replace it or plug that hole.
Old Jun 8, 2006 | 11:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Coolant temperature sensor. If it was leaking, it would be coolant, not oil.
Old Jun 9, 2006 | 12:07 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
the sensor that has broken is located on the head. it is actually the radiator fan switch. as stated it would be leaking coolant not oil. more than likely the oil is coming from a failing valve cover gasket.
Old Jun 9, 2006 | 02:41 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Ditto, its the fan switch for fan two.
As a bonus when u replace it , get a high speed fan switch(what it will be under for a GN/Turbo Regal) it will kick the fans on about 20-25 degrees cooler.
Cost is the same
Later
Jeremy
Old Jun 9, 2006 | 07:28 AM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Oil leak is prolly coming from your rear wall between the block and the intake, I had exact same problem after my rebuild. It's difficult to get a perfect seal along there.
Old Jun 9, 2006 | 10:56 AM
bneuberthz's Avatar
Car: 87 Iroc Z
Engine: l98
thanks for the replies, maybe it wasn't oil leaking, maybe it was coolant, i'll replace the sensor anyway because it's obviously broken. My fans are hardwired to be on all the time though, so maybe i'll just plug it. and if fluid still leaks I'll look for the oil leak at the back of the manifold, I just hate taking off the superram, it's a pain
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
Randomtask2
Aug 13, 2015 01:57 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
