Idle is a bit rough...New Catalytic converters
Hi everyone I just had 2 catco catalytic converters put on my car seeing as the old ones were rattling. I have not been using the car a lot but now I want to start using it since the summer is here. Anyways I am not sure if its the cats or maybe something else but seems my cars idle is rough now. When I am at a light I feel it. I also just installed 2 K&N filters and an accel coil.
Today I took the cap off to check it cleaned it and its fine. I changed the plugs on the car about 12k miles (3 years ago) ago and wires so I don't think its that. I also just cheked the engines timing and its on the money.
Anyone have any other thoughts on what I can check? I am getting no codes either.
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Do a cylinder drop test.
Get running and warm, disconnect IAC, and one-by-one disconnect injectors until you notice a cylinder that doesn't make much difference, if any. That'll be the weak cylinder. Then you have to figure out why. Might have more than one.
1992 Trans Am
May 10, 2023 07:19 PM
