Injector ohm readings
Old Jun 11, 2006 | 01:13 AM
jwenn89GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.45 9 Bolt
My injectors are reading from 3.6 to 17.1 ohms. I know that means its time to replace, but can having the ohms readings all over the board cause the injectors not to fire at all?
Old Jun 11, 2006 | 02:25 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Yes.
Low resistance basically overheats the injectors driver in the ecm and shuts it down.
When u kill power and cut it off they cool down, then it will refire until it gets too hot again.
Anything below 12 is junk according to GM.
Most stock injectros I have ohmed personally on our cars were high 16 low 17 ohm range.
Junk them and get some new ones.
later
Jeremy
Old Jun 12, 2006 | 09:50 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
