where can i get a maf burn off relay
Old Jun 11, 2006 | 04:27 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
just got the code 36 today car runs fine though no change. do auto parts stores carry this relay or do i need to go to gm. also how soon do you guyss think i should replace this relay cause im on a kinda tight budget.
Old Jun 11, 2006 | 04:47 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Auto zone definitely can order it. I doubt anyone stocks it. I always grab a handful from junkyard cars to keep as spares. There are several different part #s for that style GM relay (also used for fuel pump, etc) that all cross reference the same replacement part #.
Old Jun 11, 2006 | 04:53 PM
Engine: 383 HSR EBL
where exactly is this maf relay anyway???
Old Jun 11, 2006 | 05:02 PM
G-Ride14's Avatar
Car: 1988 GTA
Transmission: 700-R4
Axle/Gears: 9-Bolt 3.27
On the drivers side firewall.
Old Jun 15, 2006 | 02:36 PM
IrS89IROC's Avatar
Car: 89 IROC-Z
Engine: 355 L98
Transmission: 2.77 700R4 Auto
Advance or autozone it is the Gp sorensen MR21 or 22 i think. I had the guy just let me search through all their relays until i found one that looked the same and it worked. Ill repost again after i go in the garage later and ill see what the box says
Old Jun 15, 2006 | 02:40 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
MR44. Advance Auto Parts should keep it in stock. If not, there is also a Factory Air brand fan relay that should cross to the MR44 number (dont remember the Factory Air part#).
Old Jun 15, 2006 | 04:23 PM
verate's Avatar
Car: 86 Z28 Project
Engine: Currently 305 TPI soon 355 tpi/vort
Transmission: Bah 700R4
I went to my local napa and they had one in stock for like $10
Old Jun 15, 2006 | 10:34 PM
Engine: 383 HSR EBL
thanks for the replies i was able to get one and the code is now cleared
Old Jun 15, 2006 | 10:37 PM
IrS89IROC's Avatar
Car: 89 IROC-Z
Engine: 355 L98
what year. my 89 has the NON-rounded rectangular one. and all the others are rounded off.
Old Jun 16, 2006 | 07:46 AM
Duts87ss's Avatar
TpiParts.net shows the 89 burn-off relay as the round type. If yours is different, you'll just have to see if you can cross reference the number on the one you have.
BumpaD82
Feb 26, 2016 02:57 PM
my86bird
Oct 23, 2015 12:20 PM
Logan Bryant
Sep 23, 2015 06:51 AM
gta892000
Sep 16, 2015 12:37 AM
