swapin ported tpi parts...any tips/tool/info i need to know?
Old Jun 13, 2006 | 01:01 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
well i got my port work done on my slp runners and plenum...and i am about to swap them out for the stock runners/plenum....i have never done this befor so i was wondering do i need to pull the injectors and fuel rail to swap my parts? is there anythin i need to know when doin this swap? any tips/tools ect.. thanks
Old Jun 13, 2006 | 12:11 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
pretty basic tools is all you need. Just remeber to go gently when takeing off the plenum , it may be stock on there
also remeber the IAT under the plenum , just don't rip it off .
Old Jun 13, 2006 | 12:29 PM
Ant's Avatar
Ant
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
You have to pull the plenum off and loosen the bolts to the runners. I believe the passenger side runner can be pulled out with out removing the fuel rails but I know that for the driver side runners you have to pull the fuel rails off of the intake base.
Old Jun 14, 2006 | 09:54 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Did you pass your etest?
Old Jun 14, 2006 | 11:22 PM
Car: 92 1500p\u 2wd
the paper said i did!!! to a friend at the station......so im not sure if it would or not??
Old Jun 17, 2006 | 04:15 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
As many times I've taking mine apart in 20 yrs I've never had to remove the fuel rails to remove the runners.Just switched from the stock to the ported SLP runner last week.
Old Jun 17, 2006 | 08:38 PM
Car: 92 1500p\u 2wd
did you notice a good diff in power...with the slps?
Old Jun 17, 2006 | 10:13 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
I've been switching between the SLP's and the stock one's since 2002.My best run was with the stock runners but I've ran more 13.9's with the SLP's.
Old Jun 18, 2006 | 12:59 PM
Car: 92 1500p\u 2wd
with mine havin a lot of port work done to them im hope it will make even more of a diff...wel see i guess
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
mx127
Aug 10, 2015 08:13 AM
