TPI Runner Install
Old Jun 13, 2006 | 12:26 PM
LeonardS's Avatar
TPI Runner Install
I finally received the injectors for my 92 Z28 yesterday. I installed them and the fuel rail. Then I installed the runners......partially. I can not get to the two bottom bolts on the passenger side runners. There is a large 1" diameter wiring loom that runs between the runners and the valve cover on the passenger side. I can lift it up slightly to gain some access to the bolts but can not get the T40 bit started on the bolts. Has anyone done this on their 92? I have 1/4" and 3/8" swivels, extensions, t40 bits in 1/4 and 3/8 drive, flex shaft bit driver and none of these seem to help with access.
I did leave the bolts in the runners so they are in position and I have the other bolts started. I quit working on it last night just to get some ideas from the experts that have done this before. My right side valve cover/wiring looks nothing like the motor in the instructions on changing the injectors. That motor seemed to have no wiring loom issues. Mine definitely does!!
Thanks for any tips/tricks you can provide!!
Leonard
Old Jun 13, 2006 | 12:31 PM
Ant's Avatar
Ant
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
It will be a whole lot easier to get those bolts in by just taking the valve cover off.
Old Jun 13, 2006 | 12:37 PM
LeonardS's Avatar
I would be happy to do that if it helps. Have you done this so you know it works? The valve cover will probably be a bear to get off also with all the hoses and wiring.
Old Jun 13, 2006 | 12:55 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
If you have the smog junk, then definetly taking off the valve cover works!
I just put new runners on this weekend and I didn't have to take the valve covers off. Try putting the bottom long bolts on the runner then slip it in to place. I didn't use a swivel, either.
Good luck.
Old Jun 13, 2006 | 12:58 PM
Guest
Guest
Posts: n/a
I wouldnt take the valve cover off. You should be able to get the loom out of the way enough to get to the bolts. Maybe pull some of the connectors and lift it up, or maybe try pushing down on it a little but be careful because sometimes those looms get brittle over time. I doubt yours is with such low miles but who knows. If you use a torx bit and long extension, you can tighten that bolt with the extension just resting on the top of the valve cover. I've used a flex joint to avoid scratches on the cover but a piece of cloth between the two should suffice as well.
Can you take a pic of the problem area?
Old Jun 13, 2006 | 01:15 PM
LeonardS's Avatar
It worked fine on the driver side but there is a ton of shi_ in the way on the passenger side. I'll give it a shot again tonight and see if it will cooperate.
Old Jun 13, 2006 | 01:20 PM
Guest
Guest
Posts: n/a
Probably the coil pack, EGR solenoid, vent tube. Most of that can be disconnected fairly easy, unbolted, and set aside until you get those runner bolts in.
Old Jun 13, 2006 | 04:15 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
It was a pain on my '91 to get those bottom runner bolts tightened. I 2nd the removal of the valve covers.
Old Jun 13, 2006 | 04:19 PM
LeonardS's Avatar
At least I know I am not alone. Those bolts are a PITA!! I was wondering about finding some with allen heads to replace them. They are easier to tighten at an angle than the T40's and they are not visable after they are installed.
Old Jun 13, 2006 | 04:52 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
ARP makes a nice bolt kit for the TPI intake
i ordered the stainless steel ones, with a small head on them.
pricey, but probably worth it, and i've always had great luck with ARP bolts
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
