Code 45 O2 Rich
Old Jun 13, 2006 | 09:22 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Code 45 O2 Rich
Hi All,
Just my cars been running a little crazy latley and it finally spit out a code. I have a Code 45 O2 Rich. Any ideas or thoughts before i get started one basices. Anyone out there ever had this code if so what seemed to be the problem? Please any help would be nice
Old Jun 14, 2006 | 12:48 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
vacuum leaks.
bad injectors.
lots of reasons for it.
Hit the basics and do a goo thourough visual inspections.
Than follow the factory flow charts.
It either died rich or something is making it think it is(or something is dead and leaking or coolant tmep sensor)
later
Jeremy
Old Jun 20, 2006 | 08:36 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
how old is the O2 sensor
Old Jun 22, 2006 | 07:31 AM
8UpAFord's Avatar
Car: 1988 Corvette
It's like brand new. The MAF was the problem, i return my MAF and kept the screens in. I'll data log it again once i drive it
Old Jun 24, 2006 | 09:03 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Wouldn't the descreened MAF make it run leanner (More cfm=less fuel?) if anything. I'm running rich right now myself and found this thread on a search. I'm hoping when I get my headers back from Jet-Hot and replace my o2 sensor, it'll get better. I'll datalog mine as well and cross my fingers. I've tried to reprogram the ECU (even though she was rich before) and updated to from the 88 program ($6E?) to the 89 version ($32B?). Anyways, I was able to change my fan temperature on/off temp, but from what I read, Air/Fuel management is a bit more tricky. I hope to get her fixed before she has any longterm damage done. She's a daily driver for me. I'll update if I figure anything out myself, but I'm open to all suggestions!
Old Jun 26, 2006 | 08:30 AM
8UpAFord's Avatar
Car: 1988 Corvette
It can make certain ranges leaner or richer. Depends I guess. With this Microtech I was Richer everywhrere almost. With my old Boash Sensor descreen i was richer only from 2000-2600. Anyway most of the time you have to make MAF or BMP( or fuel table) mods in your chip. to run clean
Luigytico09
Oct 1, 2015 08:46 AM
James Sutton
Sep 23, 2015 02:18 PM
Shane87irocz
Sep 22, 2015 06:21 PM
GTAman
Sep 21, 2015 09:57 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
