Bypassing the MAF...Can it be done??
Old Jun 17, 2006 | 11:57 PM
WSM027's Avatar
Car: 1986 Trans Am
Engine: 350TPI
Axle/Gears: Factory..for now
I searched for two days to see if there was any history on this, but all I couldn't find anything solid. No one really answered whether or not it could be done.
I have a 89 Formula 350TPI. As you know, it has the MAF between the air filter box and the throttle body.
Here's what I'm trying to do. I want to put a K&N RC-5000 filter straight out of the throttle body. Is it possible? I've seen pics of this setup on this forum, but don't know if any of them were originally MAF setups or if they are all SD's.
If it can be done, what is the process? I'm sure it's not just an unplug it and go process....(although that would be nice)
Appreciate the help fellas, and I appologize if this has already been answered, but I couldn't find it.
Old Jun 18, 2006 | 12:01 AM
dcjredline's Avatar
Car: 1989 Formula 350
You would have to convert. Your computer is looking for that MAF. No way around it and have a good running car.
Old Jun 18, 2006 | 06:16 PM
Ant's Avatar
Ant
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
Keep the maf and get a custom cold air intake made it will look cooler and perform better
Old Jun 18, 2006 | 07:05 PM
dynomaximal's Avatar
Car: 1981 Z-28
Transmission: Muncie M-20
Axle/Gears: 3:42
Many people just remove the MAF and not do a real MAP conversion even though it looks like they did. Without the maf, the engine will still run good but not great and the adal light will be on.
Old Jun 18, 2006 | 07:14 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Many people?!? Please. The few that do that are idiots and almost always figure out they are being idiotic within the first few days... likely around the first time they have to fill up.
To hang the filter off the TB you need to either convert to SD or go with an aftermarket FI set-up.
Old Jun 18, 2006 | 07:53 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Yes thats all that needs to be said.
Old Jun 19, 2006 | 12:10 PM
WSM027's Avatar
Car: 1986 Trans Am
Engine: 350TPI
Thanks for the replies gents. I know the SLP cold air intake would be better/ "look cooler", but I didn't want to drop $250 on it right now. As soon as I get back to the Mainland, I plan on dropping the 700r4 and 350TPI for an LS1 and T56 .
Just saw that setup on a few cars, knew the filter only cost $38 bucks, so I thought it could have been cool. Oh well, I'll be back in Texas in about 10 months, then the real work begins on this baby. Thanks again.
$750 L98
Feb 1, 2025 02:25 PM
djmarch
May 8, 2016 11:32 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Formula8r89
Sep 22, 2015 04:24 PM
