Speed Density
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Are you asking how to convert a mass air system to speed density? If so, what's the project and forgive me for asking but, why would you want to do that?
i want to put a k&N filter
JEGS High Performance - K&N GM TPI Throttle Body Chrome Cone Air Filter
on my 85 iroc, i fabricated a new ram air induction front the front grille and this is the last piece for my intake, than comes tb, plenum, runners, cam, heads, and header dumps. and o yea, i just need the tb plate for my nitrous setup.
L.T.M Automotive Desings
L.T.M Automotive Desings Supreme Member
The filter in the pic is designed to bolt directly onto the throttle body of a speed density system. Unless you convert to speed density, you must keep the mass air sensor in the air induction system. Converting to speed density involves the replacement of a few major components that are very sensitive to future modifications. If you just want a cool looking air filter, keep the mass air system / sensor and custom fabricate your own cold air intake. You could use the filter in the pic, but it wont be directly bolted to the throttle body.
Check Chapter 4 out
https://www.thirdgen.org/forums/diy-prom/288763-prom-tuning-guide-book.html
Elephantismo
Feb 13, 2019 12:51 AM
