tpi sending unit
Old Jun 21, 2006 | 11:08 AM
blackroc68's Avatar
tpi sending unit
i switched my tbi 305 for a 383tpi.I removed the fuel tank to change the fuel pump.The metal tube(sending unit)was bigger than the outlet on my tpi fuel pump.'It was the same size as the throttlebody fuel pump outlet"Ill get to the point is the tpi sending unit diffrent then the throttlebody sending unit? I tried using it and the hose to the pump split.Anyone know for sure if there is a diffrence?
Old Jun 27, 2006 | 11:07 AM
Vader's Avatar
Instead of using a hose, you could try a factory pulsation damper to connect the pump. They damper is a lot more flexible, and may stretch over the larger diameter tubing without splitting.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
