cfm on a stock 91 z28 5.0
Old Jun 23, 2006 | 10:13 PM
fg_stadium's Avatar
anyone know the cfm on a stock 91 z28 305?
Old Jun 23, 2006 | 10:52 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
its like 650-750 i believe
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
on what? the TPI intake itself? the runners and base or each individually? or the TB?
Old Jun 23, 2006 | 11:20 PM
fg_stadium's Avatar
the tb unit on a tpi 305
Old Jun 23, 2006 | 11:37 PM
Engine: 383 HSR EBL
like i said 650-750 on a tb with no maf its probably closer to the 750.
Old Jun 23, 2006 | 11:38 PM
fg_stadium's Avatar
is the maf removable? or does it have to be on there?
Old Jun 24, 2006 | 01:51 PM
Engine: 383 HSR EBL
if your car cdame equiped with one (which it doesnt) than yes it needs to be there. 85-89 tpi motors were equiped with a mass air flow sensor(maf). 90-92 tpi motors were equiped with what is called a speed density system , this setup utilizes a map(manifold absolute pressure, i beleive this is what it stands for) and they have no need for a maf and thats probaby why they make 5 more horse power because the maf sensor restricts air flow a little.
Cleotiz
Jan 6, 2018 08:56 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 02:00 PM
Exxon Limited
Aug 9, 2015 08:13 PM
