Porting the head side of the lower manifold?
Old Jun 25, 2006 | 08:39 PM
HD4mula's Avatar
I have found 40+ threads on porting the top eight holes of the lower manifold. I have an Edelbrock base which I'm cleaning it up to run with a set of AS&M runners and possibily a set of AFR 180s or Edelbrock Performer RPM heads. Should I do anything on the head side of the lower manifold? I measured mines and roughly the opening are 1.16" x 1.78" or about 2.06"^2. The top holes are now about 1.72" diameter and the AS&R holes are about 1.67" diameter for 2.19"^2. So I guess I should open them up a little at least to match the area of the runners. What have you done on them? Thanks.
Old Jun 25, 2006 | 09:47 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Gasket match both the heads and the intake.
Old Jun 27, 2006 | 02:18 PM
HD4mula's Avatar
So that's it? Nothing special? I guess worst case you want the head opening to be bigger than the manifold opening to avoid that little wall obstruction, right?
Old Jun 27, 2006 | 06:31 PM
Mark 89Formula's Avatar
Yep, you got it.
transaero
Aug 31, 2015 01:14 AM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
mx127
Aug 10, 2015 08:13 AM
