TPI help
Old Jun 25, 2006 | 11:06 PM
dgnretj's Avatar
Car: 1987 iroc z
Engine: 357tpi
Transmission: t5
TPI help
Ok i have an 87 Iroc with a m5 and 305 tpi... i did a motor swap to a 350 bored .040 over with aluminum edelbrock heads, new accell injectors 30lb, lt1 cam, 1.6rr, edelbrock headers and Y, i kept the original tpi. The motor ran great*aside from the timing being a little off* until one night on my way home i smelled gas... injector was leaking, i took off fuel rails and replaced the already new rubber o rings with new ones. i bolted everything back up and cranked the engine. i get a very rough idle and the car shakes and shuts off if i dont give it gas. also i had a problem of when the car was hot it wouldnt crank back over, and i read somewhere here that this may be caused due to a coolant temp sensor. anyways could someone help me out with any info on why my engine could be running like this... after just changing the O rings? ive searched for a while and found very little. thanks guys!
Old Jun 25, 2006 | 11:14 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
I wonder if the ecm adjusted for the less fuel from the leaky o-ring and now that it's fixed. It is still trying to compensate for what was wrong before hand. Kind of like a "phantom bandaid." -Just a thought.
Old Jun 25, 2006 | 11:21 PM
dgnretj's Avatar
Car: 1987 iroc z
Engine: 357tpi
Transmission: t5
have an idea how to fix that then?
Old Jun 25, 2006 | 11:25 PM
Dirtbik3r's Avatar
Try resetting the ecm. Pull its power for a few minutes. Is it running rich when it does run?
Old Jun 25, 2006 | 11:32 PM
dgnretj's Avatar
Car: 1987 iroc z
Engine: 357tpi
Transmission: t5
yeah its running a bit rich... it ran fine when i drove it down to San Diego from San jose about 500 miles for breakin... and when i was driving here it ran fine i never abused it or anything. then this happens and seeing as how i live in an apartment now and do not have access to tools im looking for a speed shop or soemthing to work on my car but san diego doesnt seem to be the place for muscle cars haha...
Old Jun 25, 2006 | 11:44 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Is it still MAF equipped? Any codes? Did you have a custom prom burned? And why'd you go that big on the injectors? Future mods?
Old Jun 25, 2006 | 11:47 PM
Ughh61's Avatar
well you may look into you may have a vacum leak
when you cahanged to O ring
ez way to check is use a propane bottle DONT LIGHT IT
and run it around the runers when running
if it reves in a spot thats your leak
Old Jun 25, 2006 | 11:51 PM
dgnretj's Avatar
Car: 1987 iroc z
Engine: 357tpi
Transmission: t5
Yes it is still MAF equiped... the injectors are for future mods and i have a chip burned but not dyno tuned. thanks for the propane idea ill have to try that as soon as i get the chance.
Old Jun 25, 2006 | 11:53 PM
Ughh61's Avatar
caution around the coil
one spark will light it
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
