K&N with MAF
Car: 87 Iroc
Axle/Gears: stock posi
K&N with MAF
is it true that the oil from a K&N air filter will ruin your MAF sensor? ive seen many posts on other places about this, is it true?
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Yes many MAF sensors have warning labels on them about the use of oiled air filters. I have used them with MAF systems and the key is to not over oil the filter. Ive never had a problem, It may also depend on how close the filter is in relation to the sensor.
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
I know that wrongly oiled K&N's can cause your computer to throw a pissy fit and start surging and whatnot. HOnestly, its not worth the 3 hp and 50 bucks for them.
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
I've never had a problem, but if you do over-oil them, just pull your MAF and blow it out with intake cleaner, or
starting fluid....
starting fluid....
Car: 87 Iroc
i mean since it comes oiled in the box is that ok? my current MAF was shot before i put the 2 K&N's in there anyway, but im gettin a new one, and i want to make sure it will be ok. so basically, its ok unless i over oil it?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i have no problems when i put in my K/N's.. i havent reoiled them yet but i even had the screens taken out of the MAF and still no problems
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
same here, i just re oiled mine and no issues, and even if maybe u think u feel a problem , just clean the maf and you will be ok.
BumpaD82
Feb 26, 2016 02:57 PM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
