painless harness question
Old Jun 26, 2006 | 08:06 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Has anyone hooked the check engine light supplied with the painless harness to the factory check engine light?
What is the easiest way
thx
jeff
Old Jun 29, 2006 | 09:28 AM
dperk's Avatar
The painless harness comes with a "detachable" engine light. It's just a light. You could unplug the light from the painless setup and wire the 2 wires to ANY light, including your factory light. Just grab the wires from your factory light and tap them into the painless harness where the light comes apart. I have not done it that way, but I have changed the painless harness to a different light. It's easy.
Old Jun 29, 2006 | 12:32 PM
jjlabinski's Avatar
Engine: shinny 350
yeah thats what i figuered but. . . the dash is wired through printed circuit and you just cant cut and splice the painless guaged wire into the circuit tape.
Old Jun 29, 2006 | 12:47 PM
Guest
Guest
Posts: n/a
The light is enabled from the ECM, so... the wire is in the IP harness. That would be the clear plastic ~17pin connector over by the ECM. I dont remember what wire is for the light, but thats where you would hook up to it. Painless did not provide that connector and probably still doesnt, but the wiring is still on the IP harness to hook up to.
Old Jun 30, 2006 | 06:23 AM
jjlabinski's Avatar
Engine: shinny 350
Yeah this is true but. . . . there is a lamp driver that operates on the ecm signal. Once you D.C. the old harness the lamp driver is out of the circuit. how is the lamp controlled in the painless set up?
thx
Jeff
Old Jun 30, 2006 | 10:14 AM
blackroc68's Avatar
The connecter is still attached to the check engine light circuit that part stays in the car.
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
