miss fire
Old Jun 29, 2006 | 08:04 PM
gta31's Avatar
Car: 87 gta
Engine: l98
miss fire
the car has a horrible miss fire after installing shorty hookers,
the shop i had put the plugs and wires in didnt have any 90 boots so they cut the wires and put 90 boots on could this be the problem, i order taylor 8mm with 90 in case but thats the only thing that would make much sense for the missfire any other suggestions
Old Jun 30, 2006 | 01:33 PM
gta31's Avatar
Car: 87 gta
Engine: l98
Old Jun 30, 2006 | 02:12 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Thats what I would say it is. I actually swapped the wires around. The 90 degree, that was on the cap, to the straight that was on the plugs. Until I could get some accell wires. I bought the custom wires so I could make my own lengths.
I bet they didnt do a very good job on the wires....or make sure they arent laying on your headers! If thats the case, there fried!
Old Jun 30, 2006 | 02:38 PM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
double check your firing order. even with new wires if they were nor properly put in a loom the wire can still touch the header. You may want to examine your wires and make sure that none touched the header. There should be discoloration, burn, or a melted area where the wires could have touched. Also check your knock sensor those plugs tend to get broken especially during header instals. Maybe the headers are allowing you to hear a miss you had before with a the new headers.
Old Jun 30, 2006 | 08:05 PM
gta31's Avatar
Car: 87 gta
Engine: l98
i can feel it now but thanks for all the help guys ill check the wires, fire order and the sensor before the new wires are put on these hack jobs arent cutting it even if it was running good
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
get the booties to put on the ends of the wires ( plug end) . I am thinking you burnt them too .
KCG
Jun 24, 2020 04:33 AM
PurelyPMD
May 5, 2016 04:57 PM
L98GTA87
Oct 19, 2015 10:43 PM
BLK87Z
Sep 18, 2015 11:29 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
