code 33 WTF? I have no MAP sensor???
Old Jul 2, 2006 | 04:15 AM
355yellowroc's Avatar
car runs great for 3 days after I removed a head to replace a damaged valve...the all of a sudden, I'm driving down the road and car starts running like **** and the SES light comes on. I pull over to get the code and it's "33"
which according to my records is a faulty MAP sensor.
FUNNY...I have an '87 IROC...NO MAP!!!!???
Any ideas?
Any help is GREATLY appreciated.
Thanks,
Troy
Old Jul 2, 2006 | 09:14 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
First throw away your cheap Autozone code book and get a factory manual :-)
Work from there.
I dont have it near me as of this moment, but I believe its a MAF related failure to the burnoff relay. (or that might be 34)
Do some searching here.
later
Jeremy
Old Jul 2, 2006 | 09:15 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
TroubleCodes.net- engine & OBD2 Trouble Codes and Technical info & Tool Store.
This should help.
Old Jul 2, 2006 | 11:49 AM
Cool, thanks for the codes link.
I was refering to my Chiltons manual. It lists a "33" as a MAP problem...go figure.
The link you provided, I assume also translates to a 350 TPI...it should I would think. I believe vin F is the 305TPI, right?
anyway, It says MAF got a bad reading.
does this mean it's toast?
I'm gonna check the TPS here in a little while with a dgital volt meter.
Anyone know if and how I can check the MAF and/or the burn off relay with a voltmeter?
Thanks.
Old Jul 2, 2006 | 11:54 AM
ok, I just looked at the 86-88 5.7 VIN 8 codes on the link SMasterson gave me....it says the same thing my chiltons does.....MAP sensor problem...???
What the hell?
think its still a MAF prob?
Old Jul 2, 2006 | 12:40 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Code 33 - High voltage/ low vaccum at the MAF or MAP .
Old Jul 3, 2006 | 12:09 PM
ok, checked the TPS voltage..it's .568 closed and 4.17 @ wot.
that should be well within proper adjustment, Right.
so I unplugged the MAF to inspect it. Everything looks ok (no broken wire, anyway).
Then I cleared the codes and fired it up.
The friggin car is running great again...?
When the MAF code first appeared, it cam about one minute after a healthy WOT launch.
Do you think maybe the TPS might be to blame even though the base and WOT readings are fine?
It's hard to see if there are any linear "spikes" or "drop-offs" with a digital vom. So there may be a problem there.
Any more ideas?
Thanks,
Troy
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
DARKmj16
Sep 9, 2015 04:07 PM
