Fuel Pressure Question, wierd noise
Old Jul 2, 2006 | 08:15 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I installed a Walbro 255 fuel pump. Also a crane cams adjustable Pressure Regulator. When I turn the key I hear the pump come on. When I turn the engine over and not start it I here a hissing. Its not a leak, it sounds like excess pressure being released into the plenum.
Is this whats happening?? If not, what is it?
Old Jul 3, 2006 | 08:52 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Make sure you didnt tear the FP diaphragm when u installed it and that it actually sealed to the regulator base.
Also did u reconnect the vacuum line?
The Walbro will be louder than stock sounding both at the rear of the car and at the fuel rail.
later
Jeremy
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
