FPR range/ratio
Old Jul 5, 2006 | 03:30 PM
TPI 85 Blazer's Avatar
Car: 1985 full-size Blazer
Engine: 350 Goodwrench
Transmission: custom 700R-4
Axle/Gears: 9.5" 4.88 with discs and anti-wrap.
FPR range/ratio
I'm wondering how much change you guys see in your fuel pressure from idle vacuum to no vacuum. I always understood that the job of the FPR was to keep the pressure drop across the injector constant. With mine, I am only seeing the pressure drop by about half as much as the vacuum I apply to it. I don't know if it's critical to have this 1:1 ratio or not. I'm also not sure if it is because I modified the stock regulator to be adjustable.
Old Jul 13, 2006 | 06:52 AM
Hmm.. I figured somebody had made a fuel pressure measurement at idle sometime.
92-Formula
Dec 12, 2015 10:34 PM
mike22115
Sep 28, 2015 04:49 AM
Lmancha96
Sep 25, 2015 08:11 PM
Strick1
Sep 4, 2015 07:11 AM
