smog pump
Old Jul 10, 2006 | 10:38 AM
monoply6's Avatar
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
smog pump
hi all nebie her from the uk ive finally got around to removing the smog gear but my question is could i use the air pump to force more air in to the inlet duct between the tb and ams or may be run a pipe where the hot water youster run in the tb to help cool it only a thought
Old Jul 10, 2006 | 11:00 AM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
probably but you can also use the smog pump as a ghetto supercharger if your creative enough.
Old Jul 10, 2006 | 12:35 PM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
thanks for your reply ill have some fun at the weekend see what happens
Old Jul 10, 2006 | 01:33 PM
CKirocZ's Avatar
Car: 1988 IROC-Z
Transmission: 5-speed
Axle/Gears: 3.08 stock
Please don't try that, it doesn't pump nearly enough air to help anything. Just remove it from the car completely.
Old Jul 10, 2006 | 02:04 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
yes agreed, its not worth the time. Just toss it out. I hope you pluged the holes in the exhaust manafolds though.
Old Jul 10, 2006 | 02:16 PM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
yes pluged the holes removed the cats and made a 3 straight through exuast the only reason i asked is i rounded the lower retaining bolt holding the pump in so i have yet to remove it ill bin it at the weekend thanks
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
