new o rings?
Old Jul 11, 2006 | 08:25 PM
dgnretj's Avatar
Car: 1987 iroc z
Engine: 357tpi
Transmission: t5
new o rings?
i bought new injectors for my tpi system but they did not come with new cllips nor do the old clips work for the new injectors. Now i have a leaky injector, which just started leaking... Are there bigger O rings to fix this problem or how could i go abuot this? either that or maybe new fuel rails? dont want to blow up my car!!!!
Old Jul 11, 2006 | 10:02 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
U prolly tweaked/pinched or tore one of the o-rings.
The smaller ones work, but I recommend non tear a car apart every other day people to get the factory equivelent replacment o-rings.
They are bigger than what u have.
Any parts store and tell them u need injector o-rings.
later
Jeremy
Old Jul 11, 2006 | 10:04 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
If you used Ford injectors they have smaller O rings.
Old Jul 12, 2006 | 12:26 AM
dgnretj's Avatar
Car: 1987 iroc z
Engine: 357tpi
Transmission: t5
thanks guys ill check those out and go get some factory o rings hope that works def dont wanna start a fire on that expensive motor!
Old Jul 12, 2006 | 04:40 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
don't worry about the clips either. I'm not using clips at all on my TPI.
Old Jul 12, 2006 | 09:20 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I just changed mine, they were bigger. (not by much) But my kit came with a plastic cone to roll the new ones on. I had no problem.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
