vats
Old Jul 14, 2006 | 04:11 PM
fbodyguy86's Avatar
Car: 92 camaro rs
vats
what exactly will the vats system do will it disable the starter or disable fuel pump or injectors just for the sake of knowing
thanks
Old Jul 14, 2006 | 04:24 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
It doesn't disable the starter, but I not sure if it effects the or the injectors. I would guess the injectors as the pump primes before you start actually cranking the car.
Old Jul 14, 2006 | 06:54 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
in my experience it only disables the injectors. but people here will say it disables both the starter and the injectors. im not saying that theyre wrong i just havent experienced both.
Old Jul 14, 2006 | 07:50 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i believe they started using the starter disable in 1990.
the VATS, when activated shuts down injector pulse on both systems.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
