No Start! Have Spark And Fuel Pressure!?! Help would be Great!
Old Jul 17, 2006 | 08:54 PM
mxzxracer16's Avatar
Hey guys I have a 1992 Speed Density 305 TPI engine. It will not start and is getting aggravating!!!!!! I have hooked up the scan tool the Tech 2 and the results are as follows:
-When I got to crank the engine over I am not getting and injector pulses on the scan tool!? Neither is it showing any duty cycle out of them.
-Also I have no DTCS it just simply will not start.
My question is what controlls the injectors and where should I be looking? Does the Oil Pressure switch have any effect over this?
THANKS GUYS ANY HELP WOULD BE GREAT THANKS
Old Jul 17, 2006 | 09:49 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I think the oil pressure switch can affect your no start situation. However, when my stoker motor would not start (I had fuel pressure, it would turn over, and I had spark), it was the electronics in the distributor. The distributor tells the ECM to fire the fuel injectors. I bought a new dizzy, solve my problem. I think that you can change out just the electronic module (sp) and save alot on money.
Old Jul 17, 2006 | 09:54 PM
Yes that is the module in the distriutor, I was going to try that In the AM because I have another sitting around. That was going to be my best guess also! THANKS for your response.
All other comments or helpful input would be great THANKS
Old Jul 20, 2006 | 01:07 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
check the wireing to the oil presure switch. Might be all messed up.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
