prom question
Old Jul 19, 2006 | 01:56 AM
madman89's Avatar
Car: 1989 iroc z
Engine: 305 tpi
prom question
hey if i swap a 350tpi into my 305 tpi i know i need to chang the prom in the ecm. but is it necessary to change the ecm? also this might be a stupid question but where is the ecm located to swith the prom?
Old Jul 19, 2006 | 02:30 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Yes, you need a new prom. Its under the passenger side dash tucked way up near the A pillar.
Old Jul 20, 2006 | 12:30 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Stock vs Stock, you need a different PROM, Knock sensor and injectors.
Old Jul 20, 2006 | 12:45 AM
madman89's Avatar
Car: 1989 iroc z
Engine: 305 tpi
would i need a different fuel pump as well?
Old Jul 20, 2006 | 06:34 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Same fuel pump, but if you plan on making more power I would recomend a new walboro pump.
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
