is it a 305 or 350????
Old Jul 22, 2006 | 11:19 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
ive got a 88 iroc vert that has a different motor in it than the original, i know all verts came with 305's but i was wondering if i could tell if it is for sure or if its a 350, i emailed the guys at summit and they said i would have to look at the numbers on the back of the motor above the bellhousing, which i dont want to do, was just wonderin if you guys knew how to tell...thanks!
Old Jul 22, 2006 | 11:30 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes, look at the numbers on the back of the block.
Or if you don't want to do that, take the head off and measure the bore.
Old Jul 22, 2006 | 01:00 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
If you took the valve cover off and got the casting number off of the cyclinder heads it might help give you a clue as to what motor it is. If it has a 305 head on it, it is probably a 305.
Old Jul 24, 2006 | 01:17 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
416, 081 - head casting numbers typically found on a 305.
Old Jul 24, 2006 | 06:28 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Those are the only 2 ways to determine the actual size of the motor. Seeing 638 or 627 stamped on the bottom of the block doesn't mean squat. Because my engine has both of those stamped on either side and it's a 305.
Head casting numbers are a good indication, but there are people who will swap out to a 350 block but keep the 305 heads. For the longest time I thought I had a 350 because of the 638 under the block because the damn thing was so quick for a 305. Then I had to remove the heads because of a bad head gasket and lo and behold, a 3.75 bore space. In a weird way I was happy that it was a 305 for 2 reasons. 1 being that it was the original block and untouched, and 2 because it was a freaky strong 305.
Old Jul 24, 2006 | 08:48 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
cool, it doesnt take much to take a valve cover off is it????
Old Jul 24, 2006 | 08:54 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
The easiest and most accurate way is to look on the back of the block. Do not trust head casting numbers since any shade tree mechanic can put 350 heads on a 305. Get a brush some engine degreaser and a mirrior... take 10 minutes and look for 5.0LG or 5.7LG then the numbers so we can look up what type of block you posess
Old Jul 24, 2006 | 09:00 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
how and where am i gonna find that, on the back of the block??.thanks guys
Old Jul 24, 2006 | 09:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
MorTec, Chevy V-8 Engine Block and Head Casting Number Locations
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
haha i cant tell by the way it drives or sounds no other ways huh....thats sucks im really wishin its a 350
Old Jul 24, 2006 | 09:11 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
that link helped..ill have to check that out tomorrow maybe thanks!!!
Old Jul 24, 2006 | 09:23 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
just let us know
Old Jul 25, 2006 | 06:21 AM
Pat Hall's Avatar
Another way to tell is the size of the harmonic balancer. The 305 balancer is smaller in diameter and thicker, the 350 one is larger in diameter and a bit thinner. Of course I agree that the block casting number is the only sure fire way to know, since any schmo can put the wrong balancer on a motor too.
Old Jul 25, 2006 | 09:28 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Yeah I wouldn't rely on the balancer, since mine has been upgraded and such when I had a 305.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
