Internal leak?
Old Jul 27, 2006 | 02:08 AM
sam's Avatar
sam
Internal leak?
Okay.. I have no idea. All i know is that the engine runs perfectly in idle and when at a stand still in drive.
Wants I start driving there is allot of hesitation... i can still bring it up to hwy speeds but something is wrong. I pulled all plugs and they were okay. I know one cylinder has about 20 psi less than the rest
What could it be? I even checked the wires.. Noticed that the one did not click onto the plug but is still in place....
Does a lose fitting on a plug cause hesitation?
I removed the distributor cap and it looked fine. There is some play in the rotor.. is that normal? I can kind of rotat slightly clockwise and anticlockwise.
The coil is the same since 88 probably.
Anyone been in the same boat or knows what it could be?
Old Jul 27, 2006 | 11:38 AM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Is your check engine light on? If so that will ussually mean it's a sensor rather than something mechanical. It it is, try jumping the two terminals at the top right with a paperclip or something and you'll get the codes to flash on the light.
Old Jul 27, 2006 | 12:23 PM
sam's Avatar
sam
no check engine lights so that kind of helps me
Old Jul 27, 2006 | 02:07 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Need to tape a fuel preasure guage to the wondow and go cruising . Tell us what happens to the preasure .
Old Jul 28, 2006 | 07:43 PM
sam's Avatar
sam
Thanks,
I did not check pressure yet BUT I located 2 plug wires that were melted through the insulation down to the core hehe. I replaced those ...runs much better but not perfect. I guess it would be a good idea to change the rest too.
Quick question.
Could a wire be bad even if i cant see much damage on it?
Thanks,
Sam,
Old Jul 29, 2006 | 11:36 PM
sam's Avatar
sam
That question is simple i am sure, yet i am not sure if I know the answer...
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
