TPI cam question
Old Jul 27, 2006 | 11:49 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
TPI cam question
I'm looking for a cam for a TPI engine that would essentially eliminate the need for an EGR valve. What kind of specs should I look for? wider or tighter lobe seperation? more or less lift? duration? This will be for a 350 down the road but just in case how about a 305 as well.
Old Jul 27, 2006 | 11:57 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
More duration and tighter lobe separation. I have an LT4 HOT cam w/out EGR and had no problems passing emissions on the treadmill.
Old Jul 27, 2006 | 03:00 PM
Mongoose's Avatar
Car: 90 Formula
Passing emissions isn't a problem as I don't have to take the sniff test anymore, just the safety test since it's pre-'96. How's the driveability of the car with that cam?
Old Jul 28, 2006 | 07:45 AM
Engine: 385 HSR
It's good. The engine idles at 800 rpm, although I've had it less than 700 rpm and it wasn't too choppy.
Old Jul 28, 2006 | 11:07 AM
Mongoose's Avatar
Car: 90 Formula
Would that cam be too much for a 305? Just in case I get into one of those dare to be different moods.
Old Jul 28, 2006 | 06:35 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
305 with lt4 hot cam sounds awesome. But the power band will be to high for a TPI intake. Would be great with an HSR, which you can get since you wont need the EGR
http://members.shaw.ca/brisk//June2006/newcam2.MPG
Old Jul 28, 2006 | 10:34 PM
Mongoose's Avatar
Car: 90 Formula
Love that sound! That's a 350 with the LT4 cam, right?
Old Jul 29, 2006 | 02:26 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
thats no hotcam in that file thats for sure.
Old Jul 29, 2006 | 01:10 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
305 and a hotcam. Read my post
The 45 less cubes dont eat up the cam as much.
Old Jul 29, 2006 | 02:04 PM
Demon355's Avatar
I'll be using the Hotcam with my LT1 intake 355 motor. That sounds sweet, I love Brisk's car!
Whats the biggest cam people run in they're TPI motors? I think mine isn't huge but it's big enough to make some power.
Old Jul 29, 2006 | 02:15 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
I am running an LT4 Hot Cam in my built 355TPI. It is a great cam, idles good at 750 - 800 but the power band is shifted to high for the intake. It really starts to pull at 3000rpms and TPI will only really pull to 5500 max.
My TPI is a BBK 58mm, Edelbrock base + runners, Accel 24 lb/hr injectors all bolted onto a pair of Trickflow 195's w/1.6 rockers.
A stealth ram intake would be the way to go, or an LT1.
To really get the most out of the cam have a custom chip burned or do it yourself. I didnt have the time to do it so I have Alvin and PCMForLess do it for me. A couple iterations with some datalogging and my car ran perfectly. Not to rich which is where it was on the stock chip.
I definately dont regret building it by any means. This car has so much torque its insane. Now my complete TPI is for sale. If anyone is interested check it out in the parts for sale section.
The other cam that will make tons of power with TPI is a Comp 502 cam and a 1.6 rocker. Max lift is .560 on both sides with similar duration as the LT4 Hot Cam.
Old Jul 29, 2006 | 02:18 PM
Demon355's Avatar
Doesn't the hotcam pull to around 5800? I read somewhere the range was like 1800-5800 or something.
Old Jul 29, 2006 | 02:27 PM
Mongoose's Avatar
Car: 90 Formula
Starting to rethink the 350 after hearing that. How well does the car run with it? Any info on his combination?
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Sanjay
Aug 12, 2015 03:41 PM
Fronzizzle
Aug 9, 2015 01:15 PM
