descreened MAF
Car: 1989 IROC-Z
Engine: 350-5.7L
Transmission: 700R
descreened MAF
I basically ripped off the screen on my MAF....did not damaged anything else in the process..just wanted to know if i did good or bad....and how this will affect anything if anything....i did these cuz i heard it is good for better airflow...i also will not be doing anything as far as reprograming...my car is basically stock...soooo.....how bad did i screw up???
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Welll....... seems like the MAF is a pretty fragile item. And very expensive. Some guys have de-screened their MAF with no problems. Other guys destroyed theirs in the process. It's a real toss up as to if it's worth the risk. Unless you're making a LOT of horsepower, like over 400, I'd say leave the screens and don't risk MAF damage. If you insist on de-screening, I'd only remove the screen on the outlet side.
Hey, I admit it, I'm chicken to try to de-screen mine. Besides, I don't think it would make any difference on an LB9 with stock innards.
Axle/Gears: 9-bolt/3.45
Safe? Yeah, no worries. You might read a lot of technical reasons why not to do it, but because so many people have done it and had no problems, it kind of makes those reasons seem more 'theoretical.'
I've read about so many more people who have had no problems than people who had problems, that it makes me wonder if the reason people had problems was because they damaged their MAF during the process, or that maybe their MAF was about to fail anyway. It just doesn't seem like failure occurred simply because the screens were out.
But one thing I didn't do was remove the fins inside. I'd have surely messed-up my MAF if I'd tried to do that!
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
I removed the screens and the fins. No problems in 8 years.
Takes a lot of time to be careful of not destroying anything.
Guess I got lucky!
Guess I got lucky!
Car: 1989 IROC-Z
Engine: 350-5.7L
Transmission: 700R
well i removed mine and drove the car a little but could not really say if i did damaged the MAF since i still have to fix the fans on the car...also i dont have a LB9...well no longer have the RS...i have a 89 IROC-Z....so i will have to wait till the weekend when i fix the fans and install some injectors since i have a damaged ones to see if the MAF is bad....i was not too careful when i descreened mine..kinda just ripped the screenes with some needle nose plyers and knife....i know i did not damaged the middle part and the wires are still there..the "hot" wires i guess....anyways...thanx for the input...also the car will stay basically stock..no major upgrades...the usual...manifold to back exhaust...better intake and MSD setup...other than that...maybe later a better cam...but nothing else....just wanted to get a better response on the car...
Sounds like the test drive went well, so I doubt you hurt your MAF. You'll be fine.
As for my LB9 reference, I assumed Tremo was making reference to his own car, an LB9. And since mine is also an LB9, I thought I'd mention it. I had seen that your car was an L98, which will prolly be even happier than an LB9 with that extra air.
Car: 1989 IROC-Z
Engine: 350-5.7L
Transmission: 700R
True...i was not reading his post correctly
i guess it helps when you read their quick bio...also i dont know if anyone has tried it...but what about gutting the intake...Y shaped thing....i read some users here cut the bottom part of it to help the car breathe better....any input on this idea....good/bad
i guess it helps when you read their quick bio...also i dont know if anyone has tried it...but what about gutting the intake...Y shaped thing....i read some users here cut the bottom part of it to help the car breathe better....any input on this idea....good/bad Supreme Member
Car: 2004 GTO
Guess I got lucky!
Guess I got lucky!
One final word of caution. If your de-screened MAF ever fails and you have to go to a parts store to buy a replacement, look out. They want your old MAF as the core for rebuilding, or they charge you extra (the core charge). Some won't accept a MAF that has been de-screened, or has had the fins ground away. If that happens, you toss the failed MAF and eat a $100 core charge.
Is there a way to remove the screens without any damage, so they could be superglued back into place if the MAF has to be returned as a core?
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
i guess it helps when you read their quick bio...also i dont know if anyone has tried it...but what about gutting the intake...Y shaped thing....i read some users here cut the bottom part of it to help the car breathe better....any input on this idea....good/badSupreme Member
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
I had to buy a new MAF for my car, and on the Bosch one which I got, there was no core I believe, but they listed another brand that did have a core. I also think it was around 100$.
Yes, MAFs have a core charge. The amount depends on which new MAF you buy. One I was reading said they would not accept a core MAF that had been altered or modified in any way. Core charges ranged from $60 or so to up about $100. Some very expensive brand new MAFs (not remans) had no core charge.
BumpaD82
Feb 26, 2016 02:57 PM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
