fuel pump alway running when ignition is on
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
hi, i have a 89 camaro tpi 350 , my fuel pump do not turn off after about 10 sec when i put the ignition on , it alway running , some on have a idea ????
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I took my t/a on about a two hour trip the other day, when I shut the car off the pump kept running for close to a minute. It sounded like it was cavatating after a few seconds, kind of like it was spinning a lot of rpms but not moving any fuel, then it would slow down like it was getting under a load again. It went back and forth like that untill it finally shut off. It did it after I arrived home as well. It does not do this when I drive the car on shorter trips, I drive the car daily and It runs just fine under all conditions. Does this sound like the oil pressure switch?
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
A good test is to take a screwdriver and tap on the fuel pump relay (one of the relays on the firewall - driver side). If the fuel pump shuts off, it's the relay. If tapping doesn't help, you can pull the fuel pump relay connector. Again, if the fuel pump shuts off, it's the relay sticking.
Another good test would be to get under the car and tap the oil pressure switch/sender. It's just above the fuel filter, sticking out of the side of the block (for post-86 engines).
Let us know what you find out. A closure in a thread is always useful!
Lou
Lou
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Another good test would be to get under the car and tap the oil pressure switch/sender. It's just above the Oil filter, sticking out of the side of the block (for post-86 engines).
Lou
Lou
ived try what you said but it still running.... i have unplugged the connector of the oil/fuel pressure switch and i jump 2 of the 3 wire and my fuel pump was running with the ignition off so i dont thinks is the oil/pressure switch is sticking...but i dont know if it seem possible but my fuel pump has start alway running on ignition when my ignition module has busted when i was in WOT .. and now my ecm seem bugged when i want to start the car, the ecm dont send any signal on the injector, i have to take off the ecm fuse and put it back like five time and then it start, now it alway do that when is cold or hot ... maybe my cheap jobber module has busted up my ecm...what you guys thinking..
maybe my ignition module have send a bad signal when he has burn...but what you mean by my ecm dont clocking ?
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
