**searched** how to modify stock valve covers to fit roller rockers...
Old Aug 1, 2006 | 03:22 PM
LVZ2881's Avatar
Car: 1988 IROC
Transmission: 5 speed
Axle/Gears: 3.08 Posi 10 Bolt w/ aluminum drums
I have just installed a set of Comp Pro Mag 1.6 roller rockers with posi-locks.
they are comp part # 1318-16
what can I do to get my stock valve covers to fit??
if they wont, what are my options for replacement valve covers???
I thought about buying adapters and running perimeter bolt valve covers, but I'm not even sure that the adapters would fit between the rockers...
Old Aug 1, 2006 | 05:49 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
Theres no need to do that all you have to do is cut the webbing that goes from the valve cover to the piece that the bolt goes through and they will fit trust me i have those same rocker arms and my fit just cut out about an inch off the bottom they will slide right on hope it helps Later Daniel
Old Aug 1, 2006 | 05:55 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I didn't even cut mine, just bent the lip at the bottom straight and squeeze the baffle a little.
Frozer!!!
Jan 19, 2024 04:55 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
