HELP MY IROC QUIT RATTLING
Old Aug 4, 2006 | 11:54 AM
ROCITUP's Avatar
MY IROC IS TIMED AT 8 DEGREES ADVANCED.THE THING RATTLES LIKE HELL UNDER LOAD.I REPLACED THE KNOCK SENSOR BUT DID NOT USE TORQUE WRENCH TO TIGHTEN IT. ALSO THE SENSOR PLUG IS NOT AS NICE AS IT SHOULB BE AND IS A LITTLE JACKED UP.ARE THESE THE CULPRITS AND DOES ANY ONE HAVE ANY RECCOMENDATIONS? RAN AT 6 DEGGREES ALREADY AND DID NOT RESPOND THE WAY A 383 TPI SHOULD. HEADERS,STOCK PLENUM,K AND N,STOCK RADIATOR. PROGRAMMED ECM FOR 383.......THANKS GUYS/GIRLS.
Old Aug 4, 2006 | 12:07 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
1st change the plug end.
What grade of fuel are you useing?
Old Aug 4, 2006 | 12:09 PM
ROCITUP's Avatar
USING CHEVRON 91 OR 76'S 91.ONLY PREMIUM. HAVE NOT CHANGED THE PLUGS IN 3 MONTHS. ONLY HAS 300 MILES ON ENGINE.
OH IM SORRY YOU MEANT THE PIGTAIL, ILL DO THAT AFTER WORK TODAY!
87iroctheo
Dec 4, 2016 11:47 AM
xxx3man`
Sep 23, 2015 10:37 PM
aaron7
Aug 26, 2015 09:45 AM
mustangman65_79
Aug 11, 2015 03:17 PM
mustangman65_79
Aug 8, 2015 12:07 PM
