compression test
Old Aug 8, 2006 | 10:38 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
compression test
looking at an l98 motor out of an 89 trans am.... what should the compression be in all the cylinders if i am going to do a compression test??
Old Aug 8, 2006 | 11:41 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
My LB9 with 150 K mi. on it was 160 psi +/- 3.5% which I think is typical.
Old Aug 9, 2006 | 12:41 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
cool beans thanks!!!!
Old Aug 9, 2006 | 08:07 AM
Vader's Avatar
The actual numbers are not as significant as the maximum difference between the numbers. A lot of variables are involved when performing a cranking compression test. Most engines with a "decent" cam will produce a lot lower compression numbers while cranking, but a lot higher actual (dynamic) compression while running. As long as all the cylinder results are within 5-10%, things are probably all good.
Old Aug 11, 2006 | 09:27 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
thx for that info Vader! I just swapped my cam and I'm going to be doing a compression test hopefully later on tonight when I get out of work.
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
