holley stealth ram
Old Aug 10, 2006 | 06:32 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
holley stealth ram
i have looked on here for the answer to this question and i have not seen it. I just got the holley stealth ram for my car and got the pressure pressure regulator with the fuel rail kit. now i am so used to the tpi set up i dont know where the shrader valve is i think it is right next to the throttle body and if that is it, what company carries a fuel pressure gauge so i can play around with the pressure? thanks guys
Old Aug 10, 2006 | 07:00 PM
bubba353z's Avatar
Car: 07 Honda CR-V
Engine: Yes, there's one in there...
Transmission: One that shifts itself
If you installed it per the directions, it's on the passenger side, front corner - by the TB.
I have one of the small Autometer gauges from Jegs.
Old Aug 10, 2006 | 08:20 PM
Car: 92 Camaro
Axle/Gears: S60 373
do you have a part number for that? also where is the actual regulator itself?
Old Aug 10, 2006 | 08:39 PM
bubba353z's Avatar
Car: 07 Honda CR-V
I don't have the number, but anything like this will work:
JEGS High Performance - JEG'S Fuel Pressure Gauge
I've got a 60psi, even though they recommend the 100psi.
The regulator is on the opposite corner - Driver's side by the firewall.
Old Aug 11, 2006 | 10:14 AM
Car: 92 Camaro
Axle/Gears: S60 373
thanks
thanks alot boss
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
