Distributor gear question
Old Aug 11, 2006 | 09:16 AM
SS ninja's Avatar
Engine: 5.7 vortec crate w/TPI
Transmission: 2004r
Do I need a special distributor gear when installing the distributor in this motor?
JEGS High Performance - GM Performance Parts 350ci / 330hp ''350 H.O.'' Engine
It's a flat-tappet cam if that helps.
I've tried searching through the forum, and I think I don't need one, but I'm still not 100% sure.
Old Aug 11, 2006 | 08:22 PM
Vader's Avatar
It doesn't specify in the build materials listing, but it's always safe to install a bronze distributor gear in case the cam is a steel billet instead of cast.
Old Aug 15, 2006 | 04:14 AM
BADCAM70's Avatar
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
Sorry to hijack the thread but i have a follow up question as i am almost in the same situation as "SS Ninja".
I have the original L98 engine with roller cam from factory in my 89Iroc can i install a aftermarket billet steel roller cam(thinking about XR258/264HR CC)and the original distributor gear can handle that or do i need to change distributor gear to a bronze drive gear also,thx any advice in this matter !?
rgds Mats
jklein337
Sep 19, 2018 06:23 PM
Caspar
Jun 19, 2016 11:19 PM
ezobens
Aug 19, 2015 10:29 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
