general timing issues - maybe a fix
Old Aug 14, 2006 | 06:52 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
ok, this is to everyone who has timing issues. in my 92 l98, i was having high ilde issues, well my dad and i took a week to find the problem, and this is it, the distributer cap has shaken itself loose, maybe try checking that, its a super easy fix that you can do with no money, jsut a timing light. the reason i say this is because we would have never found it, but i bumped it with a screw driver wile checking for vaccume leaks for the 3rd time. maybe is a issues someone elce is having, and i haver herd a lot of timing issues, hopefuclly that helps you out.
Old Aug 14, 2006 | 07:20 PM
zeppelin5000's Avatar
Car: 1991 GTA Trans Am
Engine: 355 TPI
Transmission: 700R-4
Do you mean the distributor hold-down nut wasn't fully tight so engine vibration would cause the distributor to turn gradually throwing the timing off?
Old Aug 14, 2006 | 09:14 PM
JB22's Avatar
edit, make that Zeppelin, if that was to happen, would it want to turn counter clockwise?
Old Aug 15, 2006 | 01:49 PM
Engine: 355 TPI
Well, I'd assume it would want to turn clockwise. I think, not too sure, that happened to me. I was adjusting my timing one day and set it to where I wanted it. A couple of days later, something didn't feel right. I checked again and the number was off from where I set it. I discovered that the hold down nut could have been tightened a bit more. Once I adjusted it again, I made sure to tighten it down best as I could. Since then it's been fine and has stayed where I put it. I assumed that driving the car those couple of days caused the distributor to rotate and throw off the timing. It was very slight, but we all know that the slightest turn will move that timing mark. I could have been crazy, but that's what it seemed like. Is it possible??
Old Aug 15, 2006 | 09:04 PM
dave-92gta's Avatar
well that i finnished my timing check, and well it didnt work i dtill got an idle issue, but yea that happened to me, the bolt came loose, and well i dont remeber what way it turned, but it messed things up, and well the stupid car still idles at 1400, and well i have to take it to a shop becuase i am totaly stumped...but yea, sometimes if the timing is off, it will make the car idle funny, and rough
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
ezobens
Aug 19, 2015 10:29 PM
86Base
Aug 8, 2015 01:34 PM
