TPI on a ZZ4?
Old Aug 24, 2006 | 01:06 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
TPI on a ZZ4?
I've got a zz4 crate engine with a decent cam in it. How much HP have you TPI guys squeezed out of your system? I hear the TPI system is limited but how limited is it? I sure dont need 400hp, especially when a complete TPI system is going for a few hundred on ebay.
Old Aug 24, 2006 | 02:38 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
My 89 IROC has a stock block and heads, flat top pistons, minor porting on heads and intake, 212/218 cam, TES headers and a custom chip and I got 237 RWHP.
Old Aug 25, 2006 | 09:51 AM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
The ZZ4 with a carb gets 355hp, from the information I gathered, adding a STOCK TPI to any carb tested engine, reduce the horsepower by 30. There is a good web site on this try this My 85 Z28 and EPROM Project this guy did 13.6 in the 1/4
Old Aug 25, 2006 | 10:34 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm moving this to the TPI board, since this has nothing to do with an alternative port intake, but rather an althernative to the L98 long block.
-- Joe
Old Aug 26, 2006 | 06:19 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I hope there is a problem with your engine, because that number seems really low. What kind of dyno was it? Dynojets seem to read high, while the others read low. We have a CA member with stock untouched heads and cam, Edelbrock intake and runners, and SLP 1 3/4" headers making 260 RWHP on a Dynojet. The car has gone 13.95 in the 1/4.
To the original poster, please use the search. There are a thousand posts on putting TPI on a ZZ4. My own result was 13.23 @ 107.50, and 318 RWHP, 419 RWTQ thru a T5.
Old Aug 29, 2006 | 09:54 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
running the stuff in my sig ..without turbo . It got me 251/318 to the wheels with no tuneing. Just the ZZ4 cam and the intake stuff with SLP headers.
Old Aug 29, 2006 | 11:30 AM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Here is an example for carb. reference.Stock zz4 with 650DP and 1 5/8 headers.
271rwhp
368rwtq
You need to upgrade at least the base plate and runners to get the full potential of the zz4 or run a stealth ram.
Old Sep 5, 2006 | 12:21 AM
TransAM Joe's Avatar
Be avised that the 355hp zz4 crate with a carb is dynoed at the flywheel and not the wheels and under the best conditions. But yes the carb version will do better from breathing through a better intake. So if you go with a high flow intake and large runners you will see about the same results, but with instant control of fuel and spark though a laptop.
lt500r55
Sep 1, 2021 01:30 PM
Steve78LT
Feb 24, 2016 12:15 AM
bamaboy0323
Sep 3, 2015 06:07 AM
italiano67
Aug 31, 2015 06:04 PM
Sanjay
Aug 12, 2015 03:41 PM
