injectors
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
injectors
was thinking if i keep my car i'm going to up grade the injectors.... what about some stock 91-92 z28 l98 injectors??? i can get them cheap through my work.... what is the lbs on them???
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
But if you go bigger it wouldnt hurt to get an adjustable fuel pressure regulator.
Plus you will most likly need a tune. When I went to 24# injectors from a LT1. I needed a tune.
thejimsterz28
Sep 15, 2015 04:37 PM
