Low to Mid RPM stutter
Old Sep 1, 2006 | 07:21 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Well after my engine swap from a L03 to a modified 350 TPI I'm having a but of trouble. Engine runs very strong in the upper RPMS 2500-6000. Also Idles very well 600-1800. But, in the 1800-2400 RPM range it stutters real bad. Tach jumps up constantly, and the cars jerk a bit. I have a tuned chip from PCMforless, I KNOW, never by mail order chips but I was in a hurry to get it running, and I can't even datalog with Tunerpro. I have larger injectors and World heads, etc., and though the chip would at least get my running which it did. Now if I could just get a datalog session to record I would be on my way to getting this fixed. Does this sound like a spark issue to anyone??? Oh yeah I'm running Speed Density setup.
Old Sep 1, 2006 | 07:37 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Your car needs a proper tune. It's rather simple
Old Sep 1, 2006 | 09:14 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
That's an ignition problem, definitely. Could be arcing wires, cracked spark plugs, bad module, you name it. Look for burnt wires first.
Old Sep 3, 2006 | 01:42 PM
techno101's Avatar
Car: 1989 Camaro RS
brand new plug wires, new cap and rotor, new distributor, new plugs, but I did use my old external coil from my 305. But if it were one of these wouldn't it be a constant stutter? Through the whole rpm range I mean?? I can get to to smooth out at higher rpms.
777Shock777
Oct 29, 2015 04:30 PM
Prodigious
Oct 4, 2015 11:20 PM
mdtoren
Aug 23, 2015 12:52 PM
Jake_92RS
Aug 17, 2015 09:42 AM
mdtoren
Aug 16, 2015 05:45 PM
