TPI fuel rail mod
Old Mar 11, 2010 | 10:55 PM
  #51
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Re: TPI fuel rail mod
Wow, nevermind. I read your previous post wrong. Thanks for all the help man! I'll post pics and give you all the cred when i get this done.
Just another question, can the adaptors spin freely in order to tighten up to the fuel rail hardline? If you know what I mean, like on the metal line, the male end can spin freely on the line in order to get tight with the fuel rail hard line..
Old Mar 12, 2010 | 03:59 AM
  #52
Twin_Turbo's Avatar
You screw the adapters in first, the hose ends have swivel ends, they spin freely until they are tight. The B-nut on the hose end is essentially the same as the flare nut on the original tubing.
Old Mar 12, 2010 | 08:20 AM
  #53
Stangski09's Avatar
Great thanks for the answer. So twin turbo, a local has fuel lines I can have, so he saved my ***. But I think to add some flare under the hood to go with my powdercoated intake and chrome valve covers, I may do these braided fuel lines with black and bare aluminum fittings. I will start a thread and post pics of the progress whenever I start.
Thanks for all the help guys
Old Mar 13, 2010 | 10:42 PM
  #54
powerslave's Avatar
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
Well, I finished my rails. For those that want to tap them, go ahead, it's pretty easy! Here are a pew pics of it. All that's left is a good polish before final assembly on the car.
I'm still considering the rear feed and return, but a little farther down the road.
Scott.
Old Mar 14, 2010 | 12:23 AM
  #55
Stangski09's Avatar
So I found just the stock hard lines, now question, what about the orings on the feed and return lines, can I just replace them with normal 5/8" and 1/4" orings, or do they need to be a special type? If the sizes are incorrect, please let me know.
Old Mar 14, 2010 | 10:40 AM
  #56
powerslave's Avatar
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
You can get the correct O-rings at the auto parts store, per application.
Old Apr 5, 2010 | 09:17 AM
  #57
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I modified my fuel rail for the rear in/exit and it turned out great. I used fittings from street & performance and earl's super stock hose/ends to attach to the hard lines.
Old May 3, 2010 | 08:16 PM
  #58
l84fi's Avatar
Car: 68 C10 94 Z28
Engine: 327 and LT1
Transmission: TH400 and 6 speed
Axle/Gears: 12 bolt 4.11 and posi 3.73
Originally Posted by bingo
Does anyone have a link to a site or pics on how to modify TPI rails for rear exit? I know street & performance offers this, but I was looking for something cheaper. I know this can be done I just don't know what I need to do. Pics would help if anyone has them.
I reversed the rail by simply turning it backwards.
Old Oct 24, 2010 | 10:45 AM
  #59
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
I just disassembled a complete TPI fuel rail and planning to run fuel lines with -6 AN lines, so I am also interested in this kind of modification.
I pulled the hard return line from the bottom of the regulator and I see no threads there. It seems that I have to drill the thread for the -6 AN fitting there. Am I right?
The other question is that how should I remove the feed hard line from the front of the fuel line?
Old Oct 25, 2010 | 07:55 AM
  #60
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Yes, either drill and tap or buy the bolt-in fitting from street & performance. (There are pictures above of both options)
sawzall
Old Oct 25, 2010 | 08:32 AM
  #61
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Originally Posted by calebzman
sawzall
You mean to cut the hard feed line right at the front of the fuel rail and drill the thread in for the AN fitting?
Old Oct 25, 2010 | 09:15 AM
  #62
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Yes, that will work.
Old Oct 25, 2010 | 10:10 AM
  #63
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Okay, thanks. I'll do it this way.
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
