TPI/HP & UPGRADE
Old Sep 10, 2006 | 09:43 PM
ROBS's Avatar
TPI/HP & UPGRADE
I PURCHASED A 350 TPI MASS AIR FLOW FOR MY 68 CAMARO.I PLAN TO REBUILD & UPGRADE THE CAM & THE HEADS.ANY INPUT FOR ME AND HOW CAN FIND THE HP RATING ON MY ENGINE!!!! THANKS
Old Sep 10, 2006 | 09:44 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
YOU DON'T HAVE TO YELL!!!!!! kewl beans.... nice lt4 hot cam should do the trick....
Old Sep 11, 2006 | 10:03 PM
ROBS's Avatar
PAINLESS TELL'S ME YOU CAN NOT CHANGE THE CAM AND THE COMPUTER WILL WORK OK!!!! I KNOW THE OLD SCHOOL NOT THE TPI.
Old Sep 11, 2006 | 10:20 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
first off, what year TPI is it.
most cams do require a prom change.
but your in luck because the maf system will give you more oppions to chose from. check out some of the comp compatible cams from comp and crane too.
Old Sep 12, 2006 | 08:10 PM
ROBS's Avatar
THE CAR WAS A 1986,THE ENGINE NOT SURE.THE ENGINE IS A MAF I WAS TOLD THE PAINLESS SYSTEM WOULD BE EASY THEN THE STOCK COMPUTER!!!
Old Sep 12, 2006 | 10:38 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
if you mean to get a dif computer, dont.
get a chip burned or buy a jet chip.
i looked at some cams that will work with the stock computer. and heres what i got.
comp cams:
XE256H---intake/exhaust 212/218 dur .449/456 lift 112 LSA
good for 1200-5200 rpms (i recomend this one)
XE262H--- 218/224 dur. .464/.470 114LSA (this would be nice with diff runners and Base w/full exhaust, if your willing to do all that.)
NOTE: THESE ARE FLAT HYD. CAMS FOR 86 AND EARLIER MOTORS. IF YOU HAVE A 87 AND LATER MOTOR YOU WILL NEED A ROLLER CAM.
Old Sep 13, 2006 | 03:40 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
I thought there were no 86 350 TPI cars. Didnt the 350 TPI make its first appearance in 87?
Old Sep 13, 2006 | 06:00 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
yea in irocs they did but the vette had the 350 tpi sence day one. he needs to see what hes got first.
Old Sep 13, 2006 | 07:57 PM
ROBS's Avatar
MY PLAN WAS TO UPGRADE THE RUNNERS AND THE BASE,THE HEADS AND THE CAM.WHAT DO YOU GUYS THING. BUT FIRST I NEED TO REMOVE THE ENGINE FROM THE CAR TO SEE WHAT YEAR. THANKS FOR ALL THE HELP I NEED IT.
Old Sep 13, 2006 | 11:39 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Stop using caps please.
Old Sep 13, 2006 | 11:40 PM
Engine: 350 tpi
If it is from an 86 then chances are it is a 305 TPI.
Runners intake manifold heads and cam would make a huge difference.
Old Sep 14, 2006 | 09:12 PM
ROBS's Avatar
sorry about the caps.
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 25, 2015 04:56 PM
