Shaky fuel pressure guage.
Old Sep 14, 2006 | 10:54 AM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
I'm running a AFPR and my hypertech guage pin bounces like crazy. Is that normal. I'd like to rule out a bad AFPR (no fuel leak through vac line).
Old Sep 14, 2006 | 12:10 PM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
When I check my fuel pressure the gauge is fairly steady, moves a little but not much. I'd be more worried about the fuel pump than the AFPR. I'd check with another gauge before doing anything else.
Old Sep 14, 2006 | 05:09 PM
brutalform's Avatar
Bad gauge. Had it happen to two different Autometer gauges.
Old Sep 14, 2006 | 05:28 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
That happened to me when my fuel pressure regulator bent and got stuck completely closed, I turned the bolt down a little to far and it put a slight bend in the regulator. I went back to a stock regulator and problem fixed.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
