What goes in valve cover holes??
Old Sep 8, 2006 | 05:07 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Im in the process of putting my 87 Iroc back together. When I gave the valve covers to my dad so he can hot tank them, I forgot what was in the holes for the valve covers.
I know the driver side has the oil fill cap, and in front of that there a tube that sticks in the hole. On the passenger side valve cover there is also a hole that a tube sticks into. Im know ones called the PCV valve, but whats the other one. Are they the same part??. They both have hoses conencted to them also. Im trying to get by with looking at pictures from all your guys galleries, but I can seem to find a close up of any.
Any and all help will be appreciated.
Pics coming soon.
Old Sep 8, 2006 | 05:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The other is the breather hose that goes to the throttle body before the throttle blades.
Old Sep 8, 2006 | 06:23 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Dude....first of all...Apeiron...Im gonna airbrush a picture of your face somewhere on the hood on my car...haha....uve been a great help throughout the build. Thanks man
Second...now I know the breather hose on the other side plugs into the throttle body, but what actually plugs into the valve cover....What I mean is the grommet or the part that I buy from fram. I dont know what they are called. Thanks.
Old Sep 8, 2006 | 06:24 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
I cant remember if they both had angles on them or if they are both teh same or anything,.
Old Sep 8, 2006 | 06:28 PM
brutalform's Avatar
I believe the pass. side has a simple "elbow" that the hose attaches to. Just make sure there is a baffle under it. As long as the elbow fits the hose, and your valve cover grommet, you should be OK.
Old Sep 8, 2006 | 07:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The driver side has the PCV valve, the passenger side just has a plastic elbow.
Old Sep 9, 2006 | 08:59 AM
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
Does anyone just run a breather in the passenger valve cover? Any benefit to that? -Nick.
Old Sep 9, 2006 | 10:29 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Some people do, but you can't on your MAF TPI car.
Old Sep 9, 2006 | 05:48 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
thanks guys
Old Sep 12, 2006 | 02:28 AM
pontiacpete's Avatar
why should there be a baffle under that 90 degree vent tube that goes to the throttle body?
Old Sep 12, 2006 | 06:07 AM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
I just went out to look at mine and there is no PCV on the driver side. Funny, I always thought that was a PCV connected to the hose, but it's just a 90 degree plastic piece that fits in the grommet in the valve cover. The passenger side has one attached to the hose though. By the way, if you're ever down in Hanford, look me up.
Old Sep 12, 2006 | 10:54 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah PCV on the passenger side on TPI, sorry.
Old Sep 12, 2006 | 03:15 PM
ROCITUP's Avatar
AM I GROSSLY WRONG IN THINKING THAT THE MANUAL SAYS ITS A DUEL PCV SYSTEM? IVE GOT TWO PCV'S AND I WOULD LIKE TO KNOW WHICH IS JUST A BREATHER ON MY 89 TPI. THE ONE TO THE PLENUM OR THE ONE TO THE T.B.?
I HAD TWO BREATHERS AND THE CAR RAN BETTER WHEN I RAN A PCV ON THE DRIVERS SIDE TO THE SIDE OF THE PLENUM. PLEASE SET ME STRAIGHT .
Old Sep 12, 2006 | 08:08 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
You should have a PCV on one side and a CCV (crankcase ventilationon) on the other side. Not sure what the difference between that and a regular breather is.
Old Sep 12, 2006 | 08:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A regular breather as in a miniature air filter?
If you have a MAF car, you can't use a breather. If you do you'll provide a path for unmetered air to bypass the MAF.
Old Sep 12, 2006 | 08:57 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
I have a pcv valve in both the driver and passenger side what can this hurt and where can i buy the elbow to replace the pcv valve in the passnger side?
Old Sep 12, 2006 | 09:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's probably not hurting that much if you've got the stock hose routing. You might find the elbow in the Help! section of your local parts store, or looks like P/N 10055873 at the dealer.
Old Sep 12, 2006 | 09:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I just looked in the PIM, and it looks like the PCV is still supposed to be on the driver side on TPI cars.
Old Sep 13, 2006 | 08:01 AM
MARO-MAN's Avatar
PCV is on my driver's side. Elbow on passenger's side.
Unmetered air where? Going into the port on the plenum? or the valve cover? I have ran a breather on a MAF car before?
-Nick.
Old Sep 13, 2006 | 10:55 AM
ROCITUP's Avatar
BREATHER IN PLACE OF OIL FILLER CAP
IS IT POSSIBLE MY CAR GOES LEAN CAUSE OF THIS? I PUT THE PCV BACK ON THE DRIVERS SIDE,IM GONNA PUT THE ELBOW TO THE PASS. SIDE, AND CAP THE OIL FILLER HOLE WHERE THERE'S A BREATHER NOW. HOPE THIS HELPS LEAN COND. A LITTLE BIT.
Old Sep 13, 2006 | 12:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
In the stock PCV system on a MAF car, fresh air for the PCV is taken from the air inlet behind the MAF, so that all air entering the intake is metered through the MAF. If you put a breather in, the engine starts drawing air in through the breather, which bypasses the MAF, so it no longer has an accurate measurement of how much air is going in.
Old Sep 13, 2006 | 02:28 PM
ROCITUP's Avatar
IM WORKING ON IT TODAY AT LUNCH.......I LIVE 1 MILE FROM JUNKYARD TWO BLOCKS FROM PARTS STORE. LIKE MY 2ND AND THIRD HOMES. THANKS FOR THE INFO.
Old Sep 14, 2006 | 05:55 PM
ROCITUP's Avatar
WELL I PUT A PCV ,SEALED HOSE TO T.B. AND VALVE COVER,OIL FILLER CAP AND WOW IT DID MAKE A DIFFERENCE. APERION WAS RIGHT ABOUT THE MAF NEEDING TO READ ALL AIR THROUGH THE MOTOR........THANKS ,NEXT IS THAT STOCK WEAK FUEL PUMP,INJECTORS,AND REMOVE HOMEMADE AFPR.
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
