tpi vs computer controlled carb
Old Sep 26, 2006 | 07:40 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
well i have a 350 tpi iroc that is rusted out to hell but the 350 runs and performs great im buying a car with a lg4 and was wondering what kind of gain or loss will i see swaping a lg4 top end to my l98 bottom end instead of using tpi (keeping the tpi heads though). The point of this swap is carb is easier to work on parts are cheaper and easier to tune also carb cars seem to sound meaner then fi cars. i would go non cc carb but i need emissions and im trying to find the best peforming and priced emissions passing performer
Old Sep 26, 2006 | 07:43 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
CCC < < < < < < < <TPI IMO
U can pass emissions without a ccc i bet
Because to get ccc's to run right is HELL because they wont tell you whats wrong there not sophisticated and from what ive read around here adjustability= ****
Old Oct 1, 2006 | 01:42 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Well, don't want to flame anyone, but the CCC is a 750 cfm Rochester Q-Jet that is VERY tuneable and easy to work on. The Computer Control is only for part throttle. I had one on a hopped up 350 and it ran GREAT!!!!
Old Oct 1, 2006 | 08:12 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
All CCC carbs can be tuned on the secondary side like a normal QJ.
The timing part is at a loss however. They are not sophisticated and have a limited ecm.
That being said, on the PROM board the guys have hacked some of the CCC code, so you could modify things if u wish.
The TPI gives you complete fuel and timing control and looks better :-)
later
Jeremy
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
